Tried everything, rescanning, reset to factory, changing3or 4 as main station. had 20+ channels days ago turn tv on all gone rescan got nothing ever since, switched to another antenna, get message no channels found or no channels available. turn on /off.turns its self off because no channels. tried -100 method ,maybe I did or touched wrong button along the way, help!
Tuner is ng. You can check out the repair cost but ......Another option is to buy an external HD tuner and feed that signal to your set via HDMI inputs. Cheaper than a repair.
Available on ebay eBayeBay
SOURCE: 8800 Gigaset lights up but won't turn on.
I have seen that problem before, and it is a terminal one, sorry. You can put the batteries in backwards, and it will be okay. However, once it is set in the charger and the phone turns on, thats when the damaged occured. There is a power protection circuit (for surges), but I rarely see them open for this reverse polarity instance. The polarity reversal of the batteries does not kill the display itself (I know I have replaced them to no avail), it kills a circuit driving the display and I see the bad signals coming from the CPU which is a 80 zillion leg micro surface mount which is not cost effective to replace. Needless to say, I have about a dozen or so of them in that condition. You can google Siemens Cordless Telephone repair for repair or replacement solutions.
SOURCE: I have a cordless phone/answering
Make sure your phone service provider is compatible with your home phone. If you contact them they can usually provide you with a list of incompatible phones. Next call your home # see how many rings before your answering machine picks up. Check to make sure message is clear and audible. :Leave yourself a message. Note the time it takes for your message to become retrievable. If there is a signicant delay there might be a equipment malfunction and you should contact phone manufacturer.
SOURCE: A MESSAGE KEEPS REPEATING TO PRESS REVIEW BUTTON.
Try pressing then releasing the day/check button
SOURCE: Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
SOURCE: Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
