Samsung SyncMaster 191T 19" Flat Panel LCD Monitor Logo
A
Anonymous Posted on Feb 15, 2014
Bis monitor LS19A300 - Samsung SyncMaster 191T 19" Flat Panel LCD Monitor
2helpful
I have no internet or email services on my Blackberry 8530. The top right corner shows 1xev.How can I get services my provider is at a loss.
Mack, Blackberry Internet Service (BIS) will allow you to use Blackberry features that require Internet connectivity such as web browsing, email, instant messaging, social networking, and more.
press the helpful button and follow me on fixya for more tips and info.
How to Activate BIS on Cell
How to set up my BlackBerry Internet Service BIS
https://supportforums.blackberry.com/t5/BlackBerry-Bold/Blackberry-internet-service-not-connected/td-p/1712345
How to fix internet and email on your BlackBerry smartphone
2helpful
How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
Apr 11, 2013 • Cell Phones
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
How to convert bis 10 desk set to a bis 10 wall set
Western Electric produced 2 different stands for "Classic Merlin" telephone sets. You will need to locate the stand designed for wall mounting. Such stands appear on eBay from time to time. Keep in mind that Classic Merlin telephone sets were discontinued many years ago so locating the correct base might be a bit of a challange.
1helpful
The monitor suddenly went blank and displayed "no
no signal coming out from the video card input to your monitor. better check if the vga cable is properly fix on the video card and the monitor. you may need also to disconnect the video card from the motherboard and reseat it properly.
just make sure computer is turn off when you do this.
let me know if i can help you further.
Try to pull out video card and clean the slot on motherboard then put video in. If no result replace video card.
How many lines does the at&t bis-10 phone have?
It depends on how the control unit is programmed. The BIS 10 can't be used as a stand-alone phone (as in....you can't connect it directly to a telephone line).
The BIS 10 will work with the following systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (with the proper modules installed)
AT&T Merlin Legend (with the proper modules installed)
Ricoh 3025 w WEB Image Monitor nie mozna sie zalogowac po loginie supervisor.
speak english or dutch to ander stand yo spreche dutch bis verstehiest du
2helpful
Can I make the Merlin BIS 10 Phone able to use a
Yes, Plantronics sells a myriadof different headsets that should work well with Merlin sets.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
