Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional repair tools.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: Motorola SLVR problem
your need to do a master clear on your phone...you probably downloaded a bad file from somewhere or someone and it has corrupted all u r other files.you would loose most if not all of your download stuff but this should solve the problem...
sam !
SOURCE: how to delete photos
a photo cannot be deleted when it is being used..like for eg. it is being used along with a contact or a screen saver or wallpaper..try checking if the pic is not in use and then try deleting..all the best
Happy to help
Have a nice day!
tc
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
SOURCE: I want to delete all personal information from a
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
