Bosch WFVC5400UC Washer Logo
A
Anonymous Posted on Feb 14, 2014
Bosch washer model no wfvc4400uc. won't start. error code e27
5 Related Answers
Anonymous
  • 414 Answers
  • Posted on Jul 12, 2010
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Anonymous
  • Posted on Sep 21, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Anonymous
  • 3 Answers
  • Posted on Sep 29, 2010
SOURCE: How do I clear code
I had to call a certified bosch repair center. They sent someone out who entered some sort of code to put the washer into diagnostic mode. Once it was there, the code cleared and my washer worked again.
I asked for the code, and the repairman wouldn't give it to me.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 26, 2010
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Anonymous
  • Posted on Jan 14, 2011
SOURCE: Hi, Just last week, I got a E27 error code on my
I just had the same exact problem. Did your repairman ever figure it out?
Bosch Silenceplus 44...just out of warranty... My dishwasher has an E 27 error code and will not start, anyone have any ideas?
In the instructions for different models of Bosch dishwashers, the e27 error is described as insufficient voltage in the electrical network. This means that if the mains voltage drops below 220V (or 110V in some countries), the dishwasher stops working, and the E27 error code appears.
2helpful
How to clear error code e27 on bosch vision 300 washer
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
How do I fix an error code?
The problem it's reporting is a door latch fault. It may be a faulty latch, or you MAY just be able to clear it if it was a hiccup. Try the following six steps to clear the code, then see what hppens:
·Turn the appliance knob to the off or reset position, 12 o'clock.
·Turn the knob to the 6 o'clock position.
·Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (One click clockwise).
Continue holding the spin button for about 5 seconds
·Release the spin button
·Immediately turn the knob to off
When your turn it back on it should have cleared the error code
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Error message E27 appears and washer won't operate.
E27 means there is a problem with the door lock. Unplug the machine for 5 minutes and try again. If the error code returns you will need to replace the door lock assembly.
If you have anymore questions please comment me back.
2helpful
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
3helpful
3answers
E27 and e95 code
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
1helpful
2answers
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
1helpful
3answers
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
