SOURCE: 2002 Honda 100R Need
as a starting point, screw them all the way in, "loosely" then out 2 1/2 turns
SOURCE: Where is the idle screw, air/fuel adjustment screw on a VT750Cd
It just need to be perfect keep trying different air flows
SOURCE: need to adjust my honda shadow 500 vt carburator's
start by synchronizing your throttle plates. Honda calls the next step the "idle drop procedure". u need to know if you have fuel adj. screws or air adj. screws. fuel screws will be on engine side of carb slide, air screws will be on airbox side of carb slide. start leaning out mixture, (turn in fuel screw, turn out air screw. idle will increase so keep adjusting idle back to spec.after each turn if needed. Adjust about 1/4 to 1/2 turn at a time on each carb until there is no change in idle, then richen up mixture by one half turn. If u sync throttle plates first then follow this procedure, there should be no hesitation when you "blip" the throttle, and after revving it should return to idle smooth,
