Samsung HT-TZ515T Theater System with Wireless Speakers Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks and then goes to standby. Caan you please tell me sequence to reset wireless and establish the connection
Anonymous
Level 2:
Sniper:
  • Expert 70 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
70
Questions
0
Helped
46917
Points
208
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Can one use a TX card to view a movie on a tablet on the tv screen?
The Samsung TX card is used to send part of the audio signal from the main unit to the wireless module that controls the surround sound (rear) speakers for a Samsung Home Theater system. It isn't going to act like a ChromeCast device for your tablet.
The Samsung AH81-04177J (SWA-4000) is only compatible with a small number of Samsung Home Theater systems. see http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AH81-04177J.aspx . One of the supported systems is the Samsung HT-BD3252, https://www.samsung.com/us/support/owners/product/blu-ray-home-theater-ht-bd3252-series . See the manual of the home theater system for more information: http://downloadcenter.samsung.com/content/UM/201104/20110419185210639/HT-BD3252A_XAA_0807[1].pdf .
I hope this helps.
2helpful
Will a swa 5000 tx card fit a ht-tz225 home theater ststem
Unfortunately it would appear not. I just bought an SWA 5000 for my HT TZ 225 home threatre system as it would seem the SWA 4000 has been discontinued - the HT-TZ225 refers to the SWA 4000 doesn't it.
The tx card that accompanied the SWA 5000 was too big and did not fit in the back of the DVD player so I will have to return this to the retailer and keep looking for an SWA 4000 . . .
Unless anyone has another solution.
Can a new tx card be used in a swa-4000
where can you get a tx card from, because i need one and yes it can as long it is for that specific wirless module ?
8helpful
I'm having problems getting my swa-4000 system to work tried the code and holding down the reset button i have an ht-x715t system and the tx card is in right any idea's thanks
Hope this helps!
1helpful
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
SWA-4000 Sound Interference Problem
i also have this problem not when watching dvds but when watching cable tv. would like to no what the problem is
2answers
Samsung SWA-3000 wireless receiver not linking
@Danbrazier
Your a true life saver.... thanks a million
2answers
Just connected the SWA-4000 wireless amplified to my samsung ht-z310 - the readout on the display is "Rear Chk" there is no sound from the rear speakers- any help is appreciated
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
27helpful
6answers
Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
10helpful
4answers
SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
