SOURCE: Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
SOURCE: Humidifier says reserve tank is empty when it's not.
With this model it has not only been discontinued and difficult to find repair and replacement parts. I would suggest a new product. I wish that even in theses times I had more encourageing news because most of the time if its broke fix it..but this time, It's time to go shopping, also the company has sold twice, and now goes under two sub names. Have a great day. Thank you for your time.
SOURCE: red light not turning green
there will be a water level sensor at inside wall try to fix it .it also seem to be a power failure case well since you have just got it must in warranty or free service utilise it.
If you like my suggestion then vote for me i will be thankfull
SOURCE: I have the 6 gallon humidifier and the red
The white plastic float in the bottom of the water well is stuck to the bottom. Just lift it up.
