Express Mens SelfWinding Skeleton Bracelet Watch Black Pitch Black, No Size Logo
K
Kayla Macolor Posted on Feb 15, 2014
I'm not sure how to make the time start
I bought this watch today. set the time the way the manual told me to. It's not starting. It says that it's powered by arm movement, but I'm not sure how that works. Is it just supposed to be worn and then eventually it will start telling time? Also, if it stops moving, will it stop working?
Steven Schalm
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Feb 15, 2014
Steven Schalm
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
3468
Points
20
You have to wind the watch manually after you buy it. there should be a little knob at about 3 o'clock. Turn it clockwise about 40 times. Make sure you wear it enough (8 hours a day) or else you have to wind it every day like this
I'm not sure about this arm movement.
if the watch as not been worn for a long time it's best to wind it by hand first to get it started, just make sure the winder is pushed all the way in and then just keep winding it clockwise till it start going..
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 • Watches
1helpful
Hi i just bought a "the cannon" watch from west 49 and i don't know how to get the watch to actually start. i set the time on it but it won't start ticking. i'm wondering if it's...
Hi alec,
I see that you cannon watch is not ticking even after you have set the time.
Well after you set the time you push the knob back in once the time is set right then the watch should start ticking that instant.
If the watch is not ticking at all then it is either a damaged watch or the watch sold to you may not have batteries on it.
can you give me a model and info regarding the watch maybe we can get information or a manual about the watch for further checking before considering it to be broken.
Also if you can try calling or going back to where you purchased the watch maybe they give you details on why it will not click since you just bought it I believe they will assist you if it may need replacing.
I hope that this helps.
Have a nice day,
mvincentc
Jul 02, 2011 • Watches
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
3helpful
My daughter bought a watch today and it does not have a set of directions on how to set the time, etc...
For all those who lost their Timex instruction manuals. Copy this link in to your browser and download manual for any Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads
Rate me, please.
I bought a new watch today and i cant get it to run
Watches fall into two basic categories - quartz and mechanical. If you bought a quartz watch that is battery powered you need to set the watch and push the crown in all the way to start the watch. Sometimes you need to remove a small plastic piece from the stem to push it in all the way. If you bought a mechanical watch, even if it is an automatic self-winding model, you will need to manually wind it to get it started. If you are still having problems take it back tot he dealer for a demonstration or to have the battery replaced if required. An instruction sheet and warranty card is packaged with almost all new watches. Sorry I can't be more specific but if you care to share the make and model number I may be able to help you further.
May 01, 2010 • Watches
19helpful
3answers
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 • Watches
23helpful
2answers
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
2answers
Set the date
If you dial in the date before noon make sure you stop winding the crown right after the date flips. That will give the internal mechanism the most room to cycle and not flip at noon. If you are setting it after noon wind the crown just until the date you want starts to move to the following date, but stop immediately after so as to not flip over. That way the mechanism will be close to changing the date and should flip it at midnight. Make sense? Hopefully, good luck.
Top Express Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Express Watch Expert? Answer questions, earn points and help others
