Question about Life Fitness 9500RHRT Recumbent Bike
Power lead with plug model
Hi, i have recently bought this model from auction but with power lead on rear of bike looks to of been cut away. we have no power to the bike because of this and was wondering wether anyone has schematic drawings electrically or what is needed from bike to the wall to regain power? kind regards
    Master:
  • Life Fitness Master
  • 165 Answers
Tes the charger in another receptacle wall, if is ok , test the receptacle wall if is open, reset the circuit breaker .
if his system use batteries replace, or see if they are o.k use alkaline only.
Other is everything is o.k see if the board is fault or look for some wires loose, or disconnect.
Let me know
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Posted on Jan 26, 2018
SOURCE:
Hi I recently bought a used roadmaster mt sport sx bike and the rear gear that's attached to the wheel is moves like in circles... is that supposed to happen... if not how can I fix it?
Lots of things on a bike move in circles. If you mean it moves when you pedal but does not "catch," so the bike does not move forward then that is a problem with the rear gear cluster. You need to have a mechanic look at it. If that's not what you mean you need to get help in providing a more clear explanation.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 12, 2016 | Roadmaster Cycling
Bike cutting out
make sure coils are not cracked.
Apr 08, 2014 | 2007 Honda VT125C Shadow
1981 Honda CX500D keeps stalling
Unlikely to be a starter motor try changing your spark plugs and checking battery. Hope this helps.
Oct 19, 2012 | Motorcycles
Looking for power supply for diamondback Htr 1000u.Can you help.thank you
I recently bought the same bike and had the same problem. I contacted Diamondback and they told me that power adapter fits several models. The basic specs are 120V, 60 Hz input and 9VDC 1 amp output. The OD for the plug is 5.5mm and you should be able to find these plugs/transformers at Radioshack
Dec 30, 2009 | Exercise & Fitness
Hi. I bought an AMT Millenium Falcon model kit
Hi Robert, I think I can help. I recently found this site with a lot of information about star wars model kit.
Go to this link about the AMT Millenium Falcon Cut-away version
http://www.starwarsmodels.com/mfca.html
There is a download link to the right which contains the original instructions. Even if you don't have the cut-away version I'm sure this will help!
Jim
Nov 29, 2009 | Toys
Hi guys i just bought a a 91 zx750 and the bike is dead
start with the battery and check the fuses around .
did you check as well that your cut off switch is not damaged and may earth itself .
power issue s like this one you will have to work from the battery and work your way away from it .
check all wiring for bare wires that may contact the frame .
What you may have to do also is really look at where the bike has got damage and look around for cut wires or damage items .
Sep 22, 2009 | kawasaki ZXR 750 Motorcycles
Hi - recently bought a new KingKutter 4ft bush
go to kingkutter.com and download the manual.
hatter1
May 15, 2009 | King Kutter Pull Type Rotary Kutter 72in....
Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
May 09, 2009 | Garden
Garmin quest won't swith on.
The Quest charges on about 5 volts you have to plug the cigarette adapter into a 12 volt souce, the adapter then converts it to 5 volts. If you splice 12 volts directly into the mount the quest will not work because you burn up the circuits or the battery.
Sep 11, 2008 | Garmin Quest GPS Receiver
Life Fitness 9500RHRT Recumbent Bike Logo
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
