Kenmore Elite 45986 Front Load Washer Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F05 error duet washer
Getting the f05 error, changed the ntc sensor. still getting the error...
any suggestions on what to check next?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
3024
Points
5
Check the water Inlet solenoids (Plastic thing that the water hoses connect to in the back.) and got the 800 Ohms then it is the CCU.
Jim Goldsmith
Level 3:
  • Kenmore Master 2,005 Answers
  • Posted on Jun 10, 2009
Jim Goldsmith
Kenmore Master
Level 3:
Answers
2005
Questions
Helped
736272
Points
6152
This is a water temperature sensor error check the: water temperature sensor, heating element and, element relay
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
1helpful
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
1helpful
GHW9100LW displayed F5
"F05" is an indication of a water temperature sensor (NTC) error. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
In many cases the electrical connection to the sensor comes loose due to washer vibration and needs to be reconnected.
The part number (if required) is 8181705 and listed as "NTC" at pcappliancerepair.com. Just type in your model number and you will find the part under the "Tub and Basket" heading as item 24. If the readings check good, post back and let me know. You may have problems in the heating circuit and/or a defective heating element. I hope this helps you.
F05 on screen
Hi. This is a water temperature sensor issue.
Replace any parts that is malfunctioning or defective.
1helpful
My Whirlpool Duet Washer has an F05 alarm on display
"F05" is a heating circuit failure error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Read through the link provided and let me know if you have any questions. The majority of the cases I have experienced are either a bad NTC sensor, or a loose/disconnected connector plug on the NTC.
If you require replacement parts, you can purchase at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
Some of these sites include excellent exploded view diagrams that will assist you with component identification.
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
Replace failed component.(Most common issue will be a failed water temp sensor)
Washer is leaking tremendous amounts of water. also it is giving 2 codes F05 and FH
F05 error is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge.
Suggestion: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check.
The ideal readings should be
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Finally, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful.
God Bless
2helpful
My Whirlpool Duet front load washer has code f05 and not working
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
2answers
F05 error for Whirlpool GHW9100L Front Load Washer
The following link explains the "F05" error code:
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
Alexander
vince
