Nesco Gardenmaster Digital Food Dehydrator Logo
Posted on Jun 09, 2009
Looking for instructions a food dehydrator...it's
Looking for instructions for a food dehydrator...it's an as seen on tv emson.... Or if anyone simply knows how to make things with one?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
6471
Points
35
Here is the link to down load the manual in Adobe PDF format:
http://www.nesco.com/files/pdf/food_dehydrator.pdf
Need house & home dehydrator manual
Hello, Vickie -
Do you know the model of your House & Home Food Dehydrator?
Apparently the House & Home Model LD-1010 Food Dehydrator is the same as the Magic Chef Model LD-1010 Food Dehydrator. Also, I have seen information indicating the model LD-1010 is the same as (or very close to) model 469-1. Perhaps yours is a a model LD-1010
I have not yet found a PDF version (electronic, Adobe Acrobat Reader software) of an instruction manual for a House & Home food dehydrator or a Magic Chef food dehydrator, any model.
However, I have found directions (not the full manual) for using a Magic Chef food dehydrator here:
https://www.leaf.tv/articles/instructions-on-using-a-magic-chef-food-dehydrator/
I have found manuals for other similar food dehydrators (PDF documents), which may prove instructive:
http://pdf.lowes.com/operatingguides/1000317095_oper.pdf
and:
https://www.manualslib.com/manual/107232/Mr-Coffee-Fd5.html
Note: I also found a 1997 U.S. Consumer Product Safety Commission for a K-Tel Model LD-1010 food dehydrator:
https://www.cpsc.gov/Recalls/1997/cpsc-k-tel-international-usa-inc-announce-recall-to-replace-food-dehydrators
I have not been able to determine if the K-Tel product was manufactured by the same company which made the House & Home LD-1010 Food Dehydrator or the Magic Chef Model LD-1010 Food Dehydrator. However, I recommend you read the full recall notice and be watchful for any overheating when you use the dehydrator.
Note: If you eventually choose to dispose of the dehydrator, please do not toss it in the trash. Instead, make sure you send it to electronics recycling in your area.
Best wishes.
tip
What is Food Dehydration all About
Food dehydration is a very long standing way of preserving food. In modern times, food dehydration machines have been developed, allowing people to dehydrate their food at home.
Dehydrators work by removing the moisture from food thus allowing them to last for much longer.
Because the water is removed at a very low temperature, the nutrients and enzymens of the food are not destroyed and that's why dehydrated food is seen as part of the healthy food movement.
How do you use a food dehydrator?
1. Wash and dry the foods you want to dehydrate
2. Arrange the slices on trays. Try and avoid overlapping.
3. Set the temperature using the guide. Generally the lower the temperature the greater the preservation of vitamins and nutrients.
4. Keep an eye on the trays, turning them in the dehydrator.
5. It can take anything from a couple of hours up to a day to dehydrate food, depending on the moisture levels.
6. When the food is ready store it in airtight plastic bags or containers.
Enjoy experimenting with your food dehydrator. It's fun for kids as well and is a great way of preserving fruit and vegetables when you've overbought or can see food would otherwise go to waste.
I am looking for a wiring diagram for a nesco food dehydrator fd-61
Such devices are so simply built that it should not require a wiring diagram. Did you blow a component? If it does not heat up look for a thermal cutoff.
Need manual/directions for quick minute microwave dehydrating system
WE ARE TRING TO PULL UP DIRECTIONS FOR THE EMSON QUICK MINUTE DEYDRATING
Hi I purchased a Nesco food dehydrator at a yard sale and need a manual for it . Model fd60, can I print one off the internet for this model?
I would think that any dehydrator information would work for you.
You just have to be sure the components are working (ie. fan and heating coil.) A dehydrator is pretty basic.
http://www.food-dehydrator.com/food-dehydrator/books.aspx here is a link for books on a site that sells the product.
You can find a lot of books at the library too.
This might also help, dont let the name fool you: http://www.astray.com/recipes/?show=Dehydrator%20general%20instructions
With some searching on line you will be able to find a lot of instructions and probably even ones for your specific dehydrator.
Look on forms about drying foods and ask for the basic instructions if you find you really need them after looking at the links above.
There might be someone willing to scan them and email them to you.
11helpful
Need owners manual for Nesco Gardenmaster Food Dehydrator FD-1000
Here is the User manual you require mate :
Lemme know if this resolves your query :-)
Top Nesco Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
Are you a Nesco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
