Crooked copies printing
Does this happen with all draws and or trays
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: One Copy At A Time
Are you setting the quantities in the driver properties or just in publisher? If so, do the changes reflect in Publishers settings after setting the quantity in properties. Does this only happen from Publisher, if so then it sounds like yet another MS issue to look into and not with the printer.
SOURCE: Grinding noise crooked copies machine shakes
This won't be solved without a technician I'm afraid. It sounds to me like the fuser drive gears are worn ( it could be just about anywhere though), but this would account, in many cases, for the crooked , blurred print. whatever the case, there are gears worn, or seized, and in need of replacement. I would recommend calling for service asap, becuse this type of problem will only get worse and could cause further damage to the surrounding drive system the more it is used.
SOURCE: copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
SOURCE: The ADF Konica Minolta causes paper jamp or may bend 1 corner of
hi, clean the front roller take up ADF with alcohol and the little glass
