This chainsaw has always worked until today. I was cutting a 2 inch limb and the chain stopped turning, even though the motor was running. I took the bar and chain off and cleaned everything up, reassembled the saw and had the same problem. How can I fix this?
Sounds like the sprocket could be stripped. If so, then you would need to replace the sproket. I suggest you contact Master Parts at 800-466-1446 or online at www.masterparts.net. They may be able to help you.
When you took the side cover off, was the chain on the sproket?
