I'm about ready to return this cash register before i pull out all of my hair :(. I'm trying to program the PLUs. I got the tax status for each done (not sure how) but the actually pricing is driving me crazy! According to the 2 sets of directions that i received when I purchased it. . . i am to go into program 1, then put in the plu number press the plu key, enter the plu amount and press ca/ten. Well. . . i did that and now all the PLUs show up as the PLU # (i.e. PLU key 1 - - $0.01, PLU key 45 = $0.45) To make matters worse some of the PLU keys seem now require a condimate or preperation PLU?????????? While there is a description of these two items. . . there is no explanation on how it's programmed.
Help!!!!!. . . I also have the manual for programming via windows - good luck with that - you need to understand DOS! ! ! !
Is there somewhere that i can send my menu listing, keyboard set up, etc and a flash card - have the programming downloaded to it and then simply install it that way????
HELP
Hi. You have been given the wrong instructions. That is why it is now all screwed up. Pricing is dead easy. You have condiments setup because you have set key features in prog 3 mode. It shouldn't be too hard to fix. We'll start with prices: Turn key to Program mode Type the price (no decimal point) Press a PLU (item button) to set the price to. Press SUBTOTAL To remove condiments, you need prog 3 mode. While key is on program, press 3 then SUBTOTAL. The display must change to "P3" Now press 0 (zero) then one of the PLUs that has condiments set. Press SUBTOTAL to finish. It may remove the tax status, so turn back to REG mode and test the PLU. If the tax has gone, then reprogram the tax setting for that PLU. Let me know if you get stuck. Mark
Yeah, they give you every method of programming in the manual. If you know what you are looking for, it's all in there. They are really made for programmers as they expect you to know how to program registers in general.
hi i also have a problem with this register, my pre set cash tender amount buttons have stopped working and it also wont let me enter cah amount tendered manually it just beeps and coes up with $15.00 cash each time?
How about if I want to use condiment to be linked to one PLU? How do I program it?
Thx
SOURCE: TAKE A FORCED CONDIMENT OFF A PLU ON A CASIO TE-2400 CASH REGISTE
Hi.
Try this:
Turn key to program mode.
3 SUBTOTAL
0
PLU button
SUBTOTAL
If you had tax on this button, it will need to be set again. Just let me know if it is not calculating correctly.
Mark
Hi Mark
you are awesome! ! !
I don't know why the manual couldn't give the programming steps so easily. The manual is for the TE2400, but it has additional key strokes which is what made this entire process such a nightmare. It almost seems like casio adds extra steps just to mess things up. Maybe they want people to pay for the programming.
Thanks again. . . I'll be in touch if I have any other problems. . . i'm going to start entering the names of the cashiers and PLUs
Donna
IM TRYING TO PROGRAM 500 PLUs BUT MY TE2400 WONT ALLOW ME TO PROGRAM MORE THAN 300
