Inglis 6.5 Cu Ft Super Capacity Gas Dryer Logo
A
Ann Shayla Posted on Feb 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum won't turn
This inglis gas dryer is from 1993 (Model #IA72100)... I hope to repair this myself. No problem with coil valve or heating. All vents and areas internally are lint free. A part of a jacket caught in the drum's crease and pulled out the felt ring around the dryer. I replaced it. But then the dryer had developed a grinding noise under heavier loads such as jeans or towels. I continued to use the dryer for months with regular weighted loads. Now I hear a low humming noise when pressing the start button, (like a distant jet engine warming up) the drum begins to turn but shuts off in 1-3 turns, it will start again but only if start button is held down. Drum is stiff and hard to turn by hand. The belt seems fine? What other steps could I make to elimate the problem? I hold a grudge againgst the last serviceman that charged me full price after I assisted him thoughout the removal and return of the drum... and provided him with 3 much needed glasses of icewater on a hot summer's day. Perhaps it was the toy rubber garter snake that startled him out of the basement that detered him from giving me a fair price!!! I'd like to tackle the current problems on my own if I can get a few suggestions...
Charles Ma
Level 2:
New Friend:
  • Expert 169 Answers
  • Posted on Feb 14, 2014
Charles Ma
Expert
Level 2:
New Friend:
Answers
169
Questions
Helped
40271
Points
353
Is it possible to check the bearing or oil the centre of rotation?
Testimonial: "I've oiled the shaft to the drive motor which moves more freely now but the slow, load grinding noise is worse... it sounds like it's coming from the blower wheel area but everything seeems to be clear there? Perhaps it's the best place to start replacing parts!"
  • 1 more comment
  • Charles Ma
    Charles Ma Feb 20, 2014
    I guess you may check whether the blower wheel is still rigid (not deformed) and if it is touching anything during rotation. Also, check if the bolt/screw that keep the drum to the shaft is secure.
  • Ann Shayla
    Ann Shayla Feb 25, 2014
    Thanks for all your help... it is appreciated. I changed the rear drum rollers and idler pulley. Although the belt showed no signs of wear, I change it too. Rotation has improved and there's no more grinding. So with my handy-gal work complete, it's back to sporting an apron, to tackle the heaping pile of laundry that's beginning to look like a monster lurking in the dark corner of the basement! Haha... Thanks again!
  • Ann Shayla
    Ann Shayla Feb 26, 2014
    I've spoken too soon... buzzing of the start button has returned, although there is no more grinding except as the drum first starts, on my second load the dryer shut off early and I could smell hot wires... slightly frustrating but I'll order a new motor and keep my fingers crossed.
2 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 20, 2012
SOURCE: Grinding noise coming from the drum
What is the model number of your unit?
richroth
Richard Roth
  • 9472 Answers
  • Posted on Dec 01, 2012
SOURCE: inglis dryer gets warm not hot
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
1helpful
The Kenmore 110 87880800 gas dryers starts up, ignites the gas initially, then 15 min later the dryer stops heating but continues to turn the drum. If we let the dryer sit for 20 min and turn it back on,...
Your dryer is heated by gas and what is happening is,when the coils that open the gas valve work when they are cool but once the dryer is running and the gas valve coils get warm they wont work,this is pretty typical of a bad gas valve coil.Replacing the coils will fix that.To replace the gas valve coils,UNPLUG THE DRYER, use a putty knife and place in the seam between the main front panel and the small lower front panel AT the corners and depress the clip that holds small panel to main panel.On the right side of the base frame behind the small panel is the burner asm. the coils are held to the gas valve by a bracket remove that bracket and replace the coils, they are black round shaped and one has 2 wires and one has 3 wires the plugs pull off and can be push onto the new coils with just a small amount of pressure.
The part # for the coils is 279834 They can be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
repairclinic.com
appliancepartspros.com
assuredparts.com
I hope i have helped you to be able to repair your dryer,
Gene
Aug 07, 2011 • Dryers
Inglis gas dryer, model IA72100 The drum moves but there is no heat. I have taken the front and rear panel off. for starts Is there supposed to be a pilot light? It is a older model. If there is, how do...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 • Dryers
1helpful
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
2helpful
2answers
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 • Dryers
2helpful
Inglis gas dryer heat wont stay on
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas saefty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Aug 31, 2009 • Dryers
2answers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
2helpful
2answers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
2helpful
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 • Dryers
Top Inglis Dryers Experts
john h
Are you an Inglis Dryer Expert? Answer questions, earn points and help others
