Life Fitness Lifecycle GX Indoor Cycle Logo
A
Anonymous Posted on Feb 13, 2014
Display showing strange symbol
Looks like a square with a line coming out of it
Sportsmith LLC
Level 3:
  • Life Fitness Master 920 Answers
  • Posted on Nov 11, 2015
Sportsmith LLC
Life Fitness Master
Level 3:
Answers
920
Questions
0
Helped
514257
Points
111994
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is common for a bad display board. The only resolution to this problem is to replace your display electronics or the console as a whole.
I HAVE A STARPLUS STS AND THE DISPLAY HAS GONE COMPLETELY BLANK, IT ORIGINALLY WAS DISPLAYING ODD SYMBOLS SO i UNPLAGGED TO RESET.I AGAIN TRIED UNPLUGGING TO RESET BUT STILL BLANK. ANY HELP?????
Unfortunately the display would need to be replaced. I have had to replace many in the past. Fairly simple to do if you have any phones with other problems but a working display. The display is connected by a ribbon cable and is easy to remove and replace.
Also if you have a display that is showing strange symbol/number combination replace the 4 wire line cord with a two wire line cord. For some reason that seems to help.
My student has this the casio fx 300es, and needs pi to show up as a number not as the pi symbol. How do we do this?
The calculator has two Input/Output Modes: The MathIO and LineIO modes. Line IO is the old input mode where all symbols are written on a single line. MathIO permits fractions to show as they would in a textbook (a horizontal fraction bar and two squares, one on top and the other at the bottom. Pi can be used as Pi and irrational square roots are displayed with the root symbol. etc,,
If you are in MarhIO and you get a result with fractions, radicals, or pi. you can readily convert it to its decimal approximation by pressim the SD key. If you enter some expression with fractions and radicals and you do not want the result displayed with fractions or radicals you press SHIFT = instead of =,
Now if you do not care to have ANYTHING displayed as a fraction, radical or with PI, just set the IO mode to the old LineIO.
To effect that, press SHIFT MODE to enter the SETUP. Select 2:LineIO. From that moment on you will no longer see a fraction, nor a radical nor PI, e,
If you ever reset the calculator, the MathIO mode will be restored as default IO mode.
Strange symbol on my razr v3
its sounds like you've got a new voicemail!
try having a look at this website for translating more of your mobiles funny language!
http://www.askdavetaylor.com/what_do_all_the_icons_on_my_motorola_razr_v3c_phone_mean.html
hope that helps!
cnkr
Strange symbol
This must be the channel bars you just need to press the display button from remote commander and the sign will surely be disappears.
5helpful
Ignis Oven functions
Definately the control with 2 lines where the fan kicks in. The grill and oven elements will come on. The fan will disperse the heat from the grill element evenly and more quickly inside the oven. You will need to reduce cooking temperatures by about ten percent though,or youll burn your dinner. Also keep food down ,not too close to grill element at top of oven, middle is fine. Hope this helps. Regards..
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
