Televison & Video Logo
A
Anonymous Posted on Feb 13, 2014
Panasonic TX-P50C10Y 9 digit code - TH Panasonic Televison & Video
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Apr 22, 2011
SOURCE: What is the 4 digit
Hello
Four digit universal remote code for Panasonic you wants I thinks and posts this solution
Codes are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
2helpful
Red and green vertical lines
Your problem appearing after the TV has 'warmed' up indicates a faulty electronic circuit board/power supply: if not under guarantee, it may not be cost effective to get it repaired.
Code erreur 1 panasonic tx-p50c10y
2970,2956,2981,2988. Try these codes. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Sky+ remote code tor a Panasonic TX-L37E5B TV
678 254 278 154 242 368 191 302 128 544 241 065 395
1helpful
3 digit code for viera 42in TX-L42U5B
Four digit codes for Panasonic TVs are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Three digit codes are: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
1helpful
Can my TV Panasonic TX-76PW200A display digital signals received via component in
This set is digital signal compactable. It can process and play digital inputs. Refer to its user manual for details.
I want to buy a Panasonic 32" model. I am
Those are just idenification numbers of the product and the demintion and the lenght and with of the product.
(TV) Remote Code for Panasonic TX 15LT2
For what is required, I will not pay $9. Obtained from a free site. Thank you anyway.
1helpful
2answers
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
