Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
How to replace fuse dryer frigidaire affinity
I can't find the fuse it suggest we replace in the use and care guide. Any suggestions? It is the frigidaire affinity dryer.
  • Frigidaire Master
  • 8,220 Answers
Just called frigiare about fuse,s they said there are no fuses they are referring to your circuit breakers for your house , anyway they said to unplug appliance for 15 minutes& sometimes this cures the problem
Posted on Jul 20, 2009
SOURCE:
How do I replace igniter on frigidaire gas dryer
Hello friend, thanks for your post!
Based off the information you have provided you are looking to replace the igniter on your Frigidaire dryer. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Sep 26, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Where is fuse on frigidaire aeq7000ego
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Dryers
My frigidair affinity dryer wont start it just beeps
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Affinity dryer will not start beeps three times
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 29, 2014 | Frigidaire Affinity ATF7000E Front Load...
My dryer wont stop running
Good Morning Daniela,
I see that you are having trouble with your Frigidaire Affinity gas dryer to stop running. It sounds to me like there could be something going on with the actual control panel on your appliance. It could also be something to do with the door latching mechanism. I would suggest contacting your local authorized technician to be sure that is what is causing the issue.
-Best Regards-
WP
Mar 24, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
3,848 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
