Question about Razor MX500 Dirt Rocket
How do you get the tire of the rear rim of the razor mx500 electric dirt bike???
  • Anonymous Mar 28, 2014
    I need to replace batteries for my son mx500 razor dirt bike but the old ones are soldered on
  • 71 Answers
I would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
  • Christopher
    Christopher Mar 31, 2016
    My chain broke too I'm finding a new one
SOURCE:
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
How long can the Razor MX500 Dirt Rocket be ridden after charged?
Run time depends on a few things, including the weight of the rider, the terrain being riden over and the condition of the bike.
For example, a light rider riding on flat hard packed dirt or paved road with a bike that is in good mechanical condition - tires inflated to correct pressure, chain correctly adjusted/lubed, brakes adjusted, etc. - will have a longer run time than a heavier rider on soft undulating dirt with a bike that has not been maintained.
Generally you should be able get 40-45 minutes out of a new battery.
Check out the trouble shooting guide and user manual if you are getting less than half and hour.
http://www.razorama.com/ownersmanuals.html
Jul 31, 2013 | Razor MX500 Dirt Rocket
Can you increase the speed on the new 350 razor dirt rocket
MX350 is a 24V bike.
You could change the gearing by replacing the sprockets, or you could replace the electric controller and upgrade to 36V, but you probably would be better off getting a bigger model, like the MX500, as this uses 36V already and the higher voltage allows for higher motor rpm.
Dec 26, 2012 | Razor MX350 DIRT ROCKET - BLUE
Dirt quad has wobbly tire
Well it could be the rims or the tire it self. Have it check asap by a tire shop.
ITP tires
Sep 14, 2012 | Razor USA Razor Dirt Quad Electric ATV
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
Getting Chain back on MX500
I can do it for you because I had to change my rear tire as well and I have done it before and I will do it for you free of charge but I live in Bronx, New York and I have no idea where you live LoL... If anything my E Mail is phillyphiljesus@yahoo.com
May 09, 2009 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
419 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
