Heating & Cooling Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fujitsu Reverse air con not blowing heat anymore
Air con cools ok, but when setting is on heat it only blows cold air and at a slow speed
Model # AST17RSE-w
  • Anonymous Mar 17, 2014
    amcor air con not blowing cold
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Jun 09, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
52112
Points
122
Reverse setting could need checking here sliding valve could have siezed. you would need a service Technition. your default setting is working fine so it needs to be checked on heating mode function.
My fujitsu model is blowing cold air
sorry i was answering a question about a car ac/heater .. IDK what a fujitsu is
Heat mode on Fujitsu mini split is blowing cool air. Why might this be?
cool air or cold air? possibly a stuck reversing valve, possibly no condenser!
I have a reverse cycle 4 year old fujitsu air con and when I turn it on it automatically just blows air not cold air - it seems to divert to sleep almost immediately can u help.
It should still be in warranty as Fujitsu usually goes for 5 years. Get in touch with Fujitsu to find a local warranty agent. There's not enough info in your post for a diagnosis. Are the lights flashing? If so, what sequence are they flashing? Does the indoor unit otherwise work normally in 'fan' mode? What model do you have?
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Hi i have a problem with my air con its on heat but it blows cold air and freezes up ???
Is there a dial control to change the heat setting from 1 to 10? Even if you have it on heat, if you turn it to the lowest setting (which is to cool) it would still blow cold air. Turn it up to ten - all the way and see if that solves your problem.
Also check to see if the button that says heat or air is on upside down. Pull it off and turn it over if thats the case.
1helpful
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Fujitsu reverse cycle split wont blow cold
same as car aircon, but uses different kinds of freon. check first the thermostat setting, may be it set too high. set it to 20'c. if still not cooling, check wiring on ACCU, check capacitor too.
Top Heating & Cooling Experts
Paul Carew
john h
