Hello, I have gone through all the troubleshooting processes, still get "Paper too narrow. Load wider paper and then press Enter." This only happens when try to print from printer a test page and when receiving a fax. Printer works fine when print from computer, i.e., Word, Notepad, etc. Cannot use HP call, email, etc., printer not covered. Help! I am tax preparer and need to receive faxes from my clients. Thank you, CMW
SOURCE: kindlly assist hp 2210 problem narrow paper
you have to go to the menu and change the settings , try the DEFAULT setting . also do you have the printer connected to the PC ?
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters
Information
It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured.
From the front panel:
The screen will read Cfg param val: 26
Screen will read Test -001+
SOURCE: My printer won't print from the computer command; it will print fax or copy a paper.
MY PRINTER WONT PRINT FROM THE COMPUTER. IT WILL COPY A PAPER, BUT NOTHING FROM THE COMPUTER COMMAND.
SOURCE: I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
SOURCE: hp psc 2210 all in one series printer: align cartridge repeatedly
Bypass the allign cartridge function bu pressand holding settup then press option. The printer will immediately acccept orders.
