2011 Chevrolet Malibu Logo
Chris Gatlin Posted on Feb 13, 2014
How do i set up phone in a 2011 malibu - 2011 Chevrolet Malibu
dwollmuth
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 11, 2014
dwollmuth
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
104
Points
Where you see the phone on the steering whell press the phone till it says bluetooth than on your phonr ask it to search for bluetooth they will find each other
  • art clark
    art clark Nov 24, 2015
    does not work. when you press the button nothing happens
1helpful
How do I change the 'Check Engine Light' light bulb on a 2011 Chevy Malibu?
Question edited for clarity.
Question moved to Chevy Malibu.
There is a good video on removing and replacing the check engine light bulb on a Mustang.
https://www.google.com/search?q=chevy+malibu%2C+change+the+%27Check+Engine+Light%27+light+bulb
Here are videos on removing the gauge cluster on a Malibu.
https://www.google.com/search?q=2011+chevy+malibu+remove+gauge+cluster
How many quarts of oil does my 2011 Malibu take
Depending on the size engine and model you have, it should be one of these.
Malibu 2.4 16V (2011 - 2012) LE5 4.7 l 4.97 US Quarts / Filter: n/a 12 months
Malibu 3.6 V6 (2011 - 2012) LY7 5.2 l 5.49 US Quarts / Filter: n/a 12 months
https://oil-change.info/chevrolet-malibu-engine-oil-capacity-usa/
How to discontect traction control for a 2011 chev malibu
Traction Control
System (TCS)
The traction control system limits
wheel spin. The system turns on
automatically every time the vehicle
is started.
. To turn off traction control, press
and release (TC) on the
instrument panel.
See owners manual at following link.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://my.chevrolet.com/content/dam/gmownercenter/gmna/dynamic/manuals/2011/chevrolet/malibu/2011_chevrolet_malibu_owners.pdf&ved=2ahUKEwjlmMyLvOjfAhXF64MKHc90BdEQFjAAegQIAxAB&usg=AOvVaw3iOnCcQd7r_K8mhXkMAK9B
Why do doors lock and unlock while in motion?
2009 LTZ/Cycling (on/off) Door Locks - Chevy Malibu Forum ...
www.chevymalibuforum.com/forums/showthread.php?t=6599
10 posts - ‎8 authors
02-17-2011, 07:26 AM ... Two or three times while driving( in motion) the door lockswill cycle two or three times through the lock/unlock positions and then will stop. ...Since i can't produce this glitch on demand there is no point taking it to the dealer. ...The Malibu system will not let you lock the doors when the door is open.
Door Lock Actuator Recall? - Page 4 - Chevy Malibu Forum ...
www.chevymalibuforum.com/forums/showthread.php?t=7950&page...
Sep 23, 2011 - 10 posts - ‎7 authors
When I was driving this afternoon, the car would unlock itself at random intervals. ... It is reasonable to expect that Chevy could design a car whose doors remain locked while the car is in motion. ... 2009 Malibu 2LT, Adopted 5-7-2011 ... If you can get them to replace ALL 4 of them for a $100 deductible, I'd ...
[PDF]2011 Chevrolet Malibu Owner Manual
https://www.chevrolet.com/.../Chevrolet/.../2011_chevrolet_malib... ChevroletChevrolet Malibu Owner Manual - 2011 ..... remotely lock and unlock the doors from up ... The trunk can only be opened when ...... the vehicle is in motion can be.
2011 Malibu lt...put transmission fluid in I think too much, now it will not go into reverse nor will it go past 4th gear
Chevrolet Malibu Recall - Read About Malibu Recalls ...
https://www.automd.com/recall/Chevrolet_m/malibu_mm/
Recent Chevrolet Malibu recalls. 2011 Chevrolet Malibu Seat Belts Recall 15V269000. Campaign Number: 15V269000 Date Manufactured: May 08, 2015‎2004 Chevrolet Malibu Recall - ‎1998 - ‎2000 - ‎2003 Chevrolet Malibu Recall
Where is the cabin air filter in a 2011 Chevy Malibu
there is no cabin filter on the 2011 malibu
Reprogram key fob 2011 chevy malibu
Unfortunately a 2011 Chevy Malibu key fob need professional programming. It requires special equipment to communicate with the car. The good news is I have some money saving tips for you.
1) Purchase the key fob online at: https://www.keylessentryremotefob.com/2011-Chevrolet-Malibu-Key-Fob-s/4413.htm
2) Find a local locksmith to program the key and remote, they will come to you for less than the dealer would charge.
2helpful
How to fold the rear seats in malibu 2011?
You should notice a looped strap of cloth next to the head rest at the top of the seat. That is the release for the seatback lock. Simultaneously pull up on the strap and pull the head rest forward to fold the seat forward. The seats are split 60/40, so each seat has its own release looped strap.
Stuck blend door on 2011 malibu causing hot air to blow
MORE PROBABLY YOU BLEND DOOR ACTUATOR WENT BAD I HAVE THE SAMEPROBLEM ON MY MALIBU 2011 JUST WENT BAD LAST WEEK BUT I ONLY GET COLD AIR AND STILL HAVENT CHANGE IT DID U FIX YOUR ?????WHAT WAS THE FIX
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
