Question about Water Sport
Yamaha waverunner 1200RECENtly purchased wave runner took out for 4 mile trip ran great took in for evening done inspection and realized it didnt have oil pump only a plate were it should be. so i put some oil in the carb and a little on the pistons and added a rich fuel mixture took ski out next day and idled around for about 30 min. after smoking real good it cleared up so i tried to throttle up and it tried to throttle up but was very boggy. would run upto 37mph if i pumped throttle, i decided to idle some more so idled around another 30 min n decided to throttle up again and it was a little boggy at first then took off like bat out of hell like normal and done perfect for about 5 min then same started bogging and i had to pump throttle to keep from bogging completly down to nothing. Have I ruined this engine not having the oil pump. or can i change plugs n possible rebuild carbs...
    Sergeant:
  • 257 Answers
The first thing to check would be the compression. As long as both cylinders are with in 10 psi of each other you should be okay. Both cylinders need to be at least 100 psi. That would be the minimum for a motor to start and run. It should read aprox- 150 -- 165 psi. Also i would check for a possible exhaust leak, that would cause the motor to bog down because the carb is breathing in the exhaust fumes. Try running the motor with the hood up to see if you have a leak.
Posted on Apr 25, 2017
5 Suggested Answers
SOURCE:
protek480
  • 1730 Answers
SOURCE: 95 yamaha wave runner starts
Have you changed the 'fuel filter'. That's where you start.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 29, 2009
SOURCE: 1994 Yamaha Waverunner 3 will idle but wont take throttle
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
Posted on Aug 31, 2009
PWCYoda
  • 118 Answers
SOURCE: Yamaha 1200 year 2004 triple carb. D plate
Is your accelerator pump working?
Posted on Aug 23, 2010
heimlich
  • 1978 Answers
SOURCE: 1998 yamaha waverunner xl760;just purchased it
Take the carburetors apart and clean them. There is probably water caused white corrosion in the fuel needle assemblies. Once the needles are cleaned the fuel should pump and flow through the carburetors again.
Posted on Sep 27, 2011
Help with 92 waverunner 650 no spark issue
Hi, Banjomaniac and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Thread Waverunner No Spark
1991 waverunner III 650 turns over no spark won start Want to fix for the...
Jet ski 91 Yamaha wave runner 650 with no spark need some
http://www.yamaha-motor.com/assets/service/manuals/1998/LIT-18626-03-05_371.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 01, 2016 | Motorcycles
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
Jul 17, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
What is the size and year model of my yamaha waverunner the hull id # yama31321394
Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
May 29, 2014 | Yamaha Boating
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
Jun 22, 2013 | Covercraft Personal Watercraft Cover -...
Do they have a thermostat on a 1994 yamaha waverunner 3
No thermostat just a thermo coupler to protect against overheating.
Apr 30, 2012 | Water Sport
Manual for wave runner 1991 WR650P LX
http://www.boats.net/parts/search/Yamaha/Waverunner/1991/WR650P%20WaveRunner%20LX/JET%20UNIT/parts.html. I hope this link helps, this should tell you all you need to know. Thanks for using fixya, mike
Jun 08, 2011 | Covercraft Personal Watercraft Cover -...
I HAVE A 1995 YAMAHA WAVE RUNNER SJ700 SUPER JET. I
In all the way and then out 1 and a half turns.
Oct 13, 2009 | Yamaha TT-R 250 Motorcycles
Excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
May 27, 2009 | Yamaha 12V Air Pump
Water Sport Logo
2,568 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
