McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
www.fixya.com/.../t7785814-
generator_
mcculloch_fg6000mk_
11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
www.dqrkc.com/support/t1325485-
start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
in reg to mcculloch 5700 generator smoking after about 5 minutes- the generator shorted out and now the generator isn't functional.We certainly can't recommend buying a mcculloch generator after this experience. It had only been ran 1 time, then stored for the winter.got it out during power outage and it started ok, but then it stated smoking and shut down.
Was it just the paint and oil burning off the muffler? or did it blow smoke out of the muffler like it was sucking oil?
is it still functional? does it still run?
Where was the smoke coming from? The Alternator? If so run this test.http://generatorguru.com/help-me-fix-my-...
when using machine it stops generating smoke in too short time
