Re: PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD...
All my buttons work, but the source button won't switch to aux. In. Cd and radio work fine. Sounds like you maybe have anti theft issues? Wiring harness? Check ur wires. Mine is in a 95 240sx.
Hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
if its under warranty just return that on the store or in the authorized service center.if not just bring that on your local repair shop. because there is no serviceable parts inside the unit. ty
have the same problem just my back screen buttons working. dont know what to do =] will try using remote for now but cant change cd. should i try reset ?? or i should not =]
you can try cleaning the contacts of the face and subpanel with qtips and rubbing alcohol or a pencil eraser. if that doesn't work, you may have a bad switch.
The contacts on the faceplate or radio are dirty. Remove the faceplate and thoroughly clean the copper contacts with wet Q-tips in alcohol. Also clean the ones on the radio.
The problem is the ribbon cable,and you right there is a recall for this model,you need to contact Pioneer at pioneerelectronics.com and they should repair it for you at no cost.
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
