Generally, for most of HP printers, 52 error occurs in laser scanner motor error or (motor speed not correct).
For Solution Call our Technical Support Team to solve your issues 1800 - 806 - 4515
Try to reinstall the driver for scanner again. Call HP Support for this issue (877-690-9305) Support For Hp Printer Call Toll Free 877 690 9305
Scanner error 52 turns off and turns on will be solved easily by HP Scanner Support Number 8443555111.Offered by well-trained technicians who have knowledge and earlier worked to deal with such issue available 24*7 for your support.
HP Scanner Support Number 18443555111 Scanner Repair
To solve Scanner error 52 turn off and turn on you just need to call HP Printer Technical Support Number +1-800-281-3707 toll free available 24*7 for your HP Printer Services.
HP Printer Support Number 1 800 281 3707HP Printer Technical Support
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal
hardware error.
Recommended Action
SOURCE: 52 scanner error problem
Perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
If this step does not resolve the issue, please repair/replace the printer.
Nikhil Gedam
Super NVRAM init
if the above step does not resolve the issue, please repair/replace the machine
Nikhil Gedam
SOURCE: scanner error 52
If you can open it, please reseat the scanner flex cable after turning the machine off. For full details on how to troubleshoot, please refer here.. Hp error code 50 - 59 Good luck. Thanks for using FixYa.
SOURCE: 52 scanner error. Turn off thenb on
52 is an internal scanner hardware error.
Unplug printer, wait 30 seconds, plug it in and power up.
Problem still there...make sure printer is plugged into wall outlet, not surge protector.
If error persists you will have to get the laser/scanner assembly replaced.
We arn't talking about the scanner/copier assembly at the top of the printer. This is the internal laser/scanner that is used for all your printing.
