From sometimes, I replaced the battery and it worked perfectly. And When not plunged it works well
SOURCE: Windows failed to start !...
Boot your computer with the recovery CD In the Drive.
You should get the option ** Boot From CD**
highlight click Yes, and overwrite the O/S.
This will re-install windows over your existing version, replacing any corrupt-deleted-missing Files.
mike @ compurepair.
SOURCE: Acer Keeps restarting
You have to reinstall your operating system. There is no other option. Bcoz every time the operating system try to operate hardware it receive wrong info from the hardware drivers. Contact me again for more info
SOURCE: acer aspire one stuck on windows safe mode restart
If you have the option of going to a command prompt (on the choose how to start "text" screen), do it, and type at the C:> fdisk /mbr then press the ENTER key. This may fix things. Also, try removing the battery when the computer is off, wait about a minute, then replace it and start computer. This actually helps sometimes.
SOURCE: my acer netbook isstuck in the safe mode restart
if you are running XP the simplest way to go about it would be to pop in an XP cd and repair repair the file system. the not so easy way to get your files back would be to get yourself a Linux Live CD and boot your computer into that and access your HDD, copy the files onto a USB key and key them there.
SOURCE: my acer aspire one kav60
Your boot sector is corupted. To repair boot record you must boot from Windows xp install cd (if you have windows profesional boot from the same cd, if you have home edition boot from home edition cd, if not you'll not be able to repair your windows) and follow this steps: 1-insert cd and boot from it (if not boot from cd you must go into bios and change boot option to boot from cd, you can go into bios by pressing F2 or Del button during restart) 2-after boot, computer start to copy few files on hdd, after that you must agree license agreement by pressing F8 3-in next window you are asking to repair windows using recovery console or to proceed with a new install, choose repair by pressing R 4-in next window you must choose what windows to repair usually it's c:\windows and if you have only one windows installed press 1 and hit enter 5-now you have to enter a command line a-write "fixboot" without quote and hit enter, then computer ask you if you want to write a new boot sector press y and hit enter, this is gone fix your boot sector b-write "fixmbr" without quote and hit enter, then computer ask you if you want to write a new mbr sector, press y and hit enter, this is gone fix mbr record After that you must be able to reboot normally your computer. Good luck!
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS
STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE
MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR
PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL
MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS
WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY
SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
