Tefal UltraGlide Easycord FV4256 Iron Logo
A
Anonymous Posted on Feb 13, 2014
Cord on teffal steam iron getting hot - Tefal UltraGlide Easycord FV4256 Iron
5 Related Answers
Anonymous
  • 623 Answers
  • Posted on Aug 19, 2008
SOURCE: Tefal Express Steam Generator Iron, GV7150
check for loose wires
charleshucke
Charles Huckeba
  • 1114 Answers
  • Posted on Mar 04, 2011
SOURCE: My steam cord outer covering is all frayed at the
This the link you can use to order new parts for your iron,
http://www.unbeatable.co.uk/spares/tefal_irons-parts-repairs.html
Anonymous
  • 33 Answers
  • Posted on Jun 14, 2011
SOURCE: I have a Tefal Pro
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
Anonymous
  • Posted on Sep 13, 2011
SOURCE: tefal pro express steam generator
there's 2 possibility:
1- electonic board is defectuose 2- pump is defetuose
Anonymous
  • Posted on May 08, 2012
SOURCE: I have Tefal protect turbo steam generator iron.
I have steam but the iron is not heating up
1helpful
Should the cable from the machine to iron get hot
If the iron is a steam-iron with a steam tank in the base-unit, then steam is carried up the connecting pipe & it will get hot in normal use.
If you put water into the iron itself, then there is only an electric cable connecting the base & it should never, ever get hot. A little bit warm maybe, but never hot.
Best of luck.
Mar 09, 2018 • Irons
I need to repair a damaged fabric cover on my euro pro steam iron. the fabric cord cover is frayed and the rubber steam cord gets extremely hot where the fabric is frayed.
You will need to obtain a completely new power cord kit from the manufacturer. If you are not familiar with doing electrical repairs, you may want to have a technician do it. Insulation on the power cord is important for several reasons; especially a method to keep you safe from a fire, electrical burn, shock, etc.
Jan 14, 2018 • Irons
2answers
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron does not spray properly, inspect and clean the nozzle (see below).
Tefal easycord gv 5140 no steam
do this. and use the common sense and KEEP the calm. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Tefal protect concept steam button not working
hi! Long time listner, first time caller.
Iron not steaming AT ALL.
I have a tefal gv 7096
It turned on, all lights working and i can hear it heating up and when opening the calcium deposit i can see steam.
When i pressed the button - nothing. The iron it's self is hot (the plate) the lights on and but no steam.
The cord connecting the iron to the steam was also cold, so i could tell no steam was getting to the iron at all.
I wasn't sure if it was the button not working or something clogging the cord to the iron.
I did the vinegar thing. Let it sit for sometime (40 mins) and still nothing.
I did a weird thing of very carefully putting water on the plate while hot and it created steam from the plate. i think some backflowed and it started steaming, within seconds. might have happened with a bit more time anyway, but it def helped. All wokring fine now :)
Aug 10, 2012 • Irons
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Top Tefal Irons Experts
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Tefal Iron Expert? Answer questions, earn points and help others
