Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
My pen won't turn on either and none of that helped. Is there a reset button or something?
I am having the same problem. Fresh batteries that work, but the pen won't even turn on..
Same here... My oldest loved the pen and trying to set it up for my little one now. Using new and tested batteries as well and the original usb cable, all is tested and good to go but still no go. No power, no lights, no sound .... nadda. Can you help?
CCWhite13
Did you find a solution? I"m having the same problem with my daughter's Tag Reader?
when turned on pad is frozen on leap frog logo want go any further
