According to the Nintendo support site, here's what to do.
Your movements are not being correctly detected
If the Wii Balance Board is still not correctly detecting your movement, please call 1-800-255-3700 for assistance.
Here's the link if you want to see for yourself
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#movement
I think you missed this part of my solution.
This is the number for Nintendo Support.
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
this is not the problem. the only thing that may be wrong that u listed is the batteries ( is the batteris that came with it long lasting?) I was playing, and in the middle of the game, all my weight goes to the right. i check an the top left and bottom left sensors arent working. i tried the extrra sensors, but nothing happened. anout 5 months later, i checked again and still. my left side isnt functioning. what should i do? ( sorry for not much detail in my last question!)
