The last few times I turned on the laptop I received the BSOD. Now after a few years, it's completely dead of course. When I plug it in to charge, the battery light flashes green 5 times slowly, then immediately starts flashing orange quickly. The colors do not alternate and it doesn't stop flashing until I unplug it.
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Battery Light Flashes Orange and Green
The LED sequence indicates a failure in the battery. (Like one cell has low charge) As long as the overall battery output meets the minimum for system operation, the battery will work.
The average lifespan for a Portable battery is about 500 discharge/recharge cycles (1 to 2 years) anything after that is a bonus
Replace the battery, issue will go away
SOURCE: BATTERY LIGHT FLASHES ORANGE
hi,
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
