Question about Epson Stylus Photo 925 InkJet Printer
My printer is only printing half of the page - Epson Stylus Photo 925 InkJet Printer
  • Epson Master
  • 511 Answers
Half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Posted on Jun 10, 2009
SOURCE:
SOURCE: Printer only prints half a page
I have a Lexmark 5400 series printer that is only printing the top half of a page. Any suggestions anyone ?.
Posted on Mar 09, 2008
  • 69 Answers
SOURCE: printer only prints half the page
Hello Doodle,
It is the problem with the software and also the page settings. This issue can also occur due to the corrupted registry.
How ever the best way to resolve the issue is
1. Uninstall the software completely.
2. restart the computer
3. delete the temporary files
4. reinstall the updated software(do not use the cd) for your lexmark printer by clicking on the weblink below:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Once you open the webpage above select your printer model and follow the on screen instructions
Thank you. Best of Luck.
Posted on Oct 26, 2008
smunteanu
  • 43 Answers
SOURCE: Printer only prints partial page
The carousel central axel has been twisted.
Posted on Mar 18, 2008
SOURCE: HP CP1515N ONly prints half a page
Hi! i would like to ask about how to fix my printer CP1515N.
my problem is when i print the brown text or two or more color of the text it became to have shadow but the shadow not black color.
sorry my english is not so good!!
please help me to solve it
Posted on Jun 18, 2009
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Why my kyocera Fs-4020DN printer print half page?
is the image shifting ? may be registration clutch or sensor
Nov 14, 2014 | Office Equipment & Supplies
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
Tech@ccl-la.com
Apr 30, 2010 | HP LaserJet 2300 Printer
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
My canon only prints half page?
Go to print setup try to cheeck the diffult.
May 19, 2009 | Canon PIXMA iP90 Mobile Printer
Jan 20, 2008 | Dell A920 InkJet Printer
Printer problem
on photos, If you have a laser printer with half a meg of RAM and you try and print a full page graphic at 300dpi you only get half a page because the printer runs out of RAM. You can get a full page by printing at 150dpi. could also be that the encoder strip has become fogged with aerosol, and needs gentle cleaning. Good luck
Mar 25, 2006 | Dell Inkjet 720 Printer
Open Questions:
See all Epson Stylus Photo 925 InkJet Printer Questions
Epson Stylus Photo 925 InkJet Printer Logo
3,713 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
