Sony Walkman NWZ-S616F MP3 Player Logo
Posted on Jun 08, 2009
Can't get the right usb connection on my mp3 to download music.
When i plug in my sony walkman mp3 player to my computer it says connecting usb(mtp). I've never seen that (mtp) on there b4 and its not letting my downloads go on my mp3 player. Please help.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1233
Points
9
Win Xp -> Go to Start-Control Panel - System - Device Manager - Last on the list is MTP player, click on it and select upgrade driver - i will choose myself - i there will be two options ( MTP player and USB mass storage device ) Pick Usb mass storage and then OK. Then your MP3 player is visible in My Computer
CAN I CHANGE THE SETTINGS FOR HOW IT DOCKS I WANT TO PLUG INTO MY CAR STEREO USB TO PLAY, BUT UNABLE TO AS IT DOCKS
The USB cable supplied with the Walkman Player is for connecting it to the Computer. Once you connect the Walkman Player to the Computer, it will detect it as an MTP device.
For connecting the Player to a Car Audio System, it should detect it as an MTP Device. The operations by connecting the USB of the Player to the Car Audio System is not guaranteed by Sony.
However, you can connect the Headphone Out of the Walkman to the AUX Input jack on the Car audio system (if available).
Thanks for using FixYa
3helpful
2answers
What driver do i use for my sony mp4 player... model number nwz-s616f.. please help me
It is not required to install any Driver for connecting the Walkman Player to the Computer. The Driver for recognizing the Walkman Player as a MTP Device is already installed in the Computer. You can install the supplied Windows Media Player 11 Software for transferring the files to the Player. You can either Drag and Drop the files using the Windows Explorer to the MUSIC Folder which appears as a Removable Drive or can use the Windows Media Player 11 for transferring. If the Player is not recognized by the Computer, try connecting to different USB ports and try re-installing the USB Driver from the Device Manager.
Thank you for using FixYa!
Would like to download moives and music on dmp what d i need t do using a public cumpter
This may be hard to do if you do not have permission to change the computers settings. The Sony uses what is called MTP mode to load files. Sony support has two programs on their site that lets you add files to your player. One program is called Media Manager for Walkman. If using a public use computer they may not let you install a new program on the mach. Using a Sony or an iPod on a public computer may be a bit tricky. they want you to use one computer only to be the main setup for any transfers. Now what does MTP stand for. .MTP stands forMedia Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP32_bing.gif players and cameras2_bing.gif to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management2_bing.gif (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode. If you use the Sony program you do not have to use W*ndows Media payer. So see if you can install this program on the computer you want to use.
2helpful
Its a sony walkman NWZ-E344 mp3 when I try to charge it,'connected USB (MTP) the timer and alarm will be invalid' shows up.Eventhough I charge it like three hours it does not charge.
First unplug device from the computer. Go to Device Manager and look for NWz-E344. It may be under Portable Devices or under disk drives. It depends on your OS. When you find it, right click and select Uninstall. After it uninstalls, connect the player to the computer. The computer should run the plug-and-play add hardware to re-add the device.
How do i make my mp3 connect with my computer
I had the same problem. I had not had any problems for months and suddenly it wouldn't connect. I got on live chat w/ Sony (3 times) and finally got someone who seemed to know what they were doing. I have a Sony computer and they had to send me a link for a USB "patch". After downloading it, it fixed it.
3helpful
Mp3 will not connect with my computer
I'm pretty sure I fixed a similar problem. Go to your device manager on your PC and uninstall the walkman driver. After this is complete just plug the walkman back into you Pc and the plug and play will download the driver again. This worked for me. My operating system is Windows vista.
28helpful
6answers
Sony nwz-b135f problem
MTP problem SOLVED!!!!! Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sony MP3 Player(NWZ-B135F). when i inserted it to my pc's USB port(which is working fine), win XP (SP 3) prompted "Found New hardware" wizard. I followed the steps and finally I reached to a step where it shows “MTP device Problem......” I tried many times with different USB ports, but the same problem happened.
Fully frustrated, I finally did what the whole world does, GOOGLE my problem. Google showed me a lot of posts but nothing could solve my problem. Microsoft was providing the MTP driver, but only after a lot of authentication and procedure, which I was not going to follow….
After repeatedly experimenting by inserting my MP3 player, I got the solution!! It is as follows:
1) Insert your music player in the USB port. You will get a Hardware Installation wizard by XP.
2) Select, “No, Not this time” and click next.
3) Select “Install from a list or specific location (Advanced)”.
4) Select “Don’t search. I will search the driver to install”.
5) Select “USB Mass Storage Device” and then click "Next"
7) Wow!! Now you are done!!!
Enjoy and listen to your favorite music!!
5helpful
My mp4 player wont connect keeps coming up connecting usb mtp
Great Solution by  DCDW
Rank: Apprentice
Rating: 95%, 43 votes
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button.
Clicking on the "System Devices" tab should have "Walkman" or MTP device. Right click on it and go to properties, now before doing anything it should say "Location -- ------ Location 0 (Walkman)" if not try unplugging the walkman and see if the MTP device you're looking at is removed from the list, just to make sure it's the right device we're looking for.
If you've confirmed it's the Walkman, click on the "Driver tab" and click on "Update Driver...". Then click on the "Install from a list or a specific location (Advanced)" option and click "Next". Now select the "Don't search. I will choose the driver to install." and click next. It should now bring up 2 driver choices, one being "MTP Device" and the other "USB Mass Storage Device". Select the USB option and select next, it will then install your walkman as a USB storage device and after that's done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in "My Computer"
3helpful
2answers
NWZ-B103F MP3: connected to USB port on pc( vista) and tried on laptop( xp)
68helpful
9answers
Sony Walkman NWZ-B105F MP3 wont connect
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
