SOURCE: Karcher power washer electric K3.97
have a look on karcher web site
www.karcher.com
click on europe
then click in international
go to service then spare parts
put in k3.97 and have a look.
hope that will help
damian
SOURCE: my karcher electric power washer will not
If you have used an extension cord with it you have destroyed the motor. If not, the bypass valve is stuck. On THIS diagram, section 2.1, part number 1 needs lubrication with a good waterproof grease.
SOURCE: I have a karcher power washer electric.
This could well be just needing a new motor capacitor as this helps the motor to start.
SOURCE: My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :(
If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
