Car Audio & Video Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One channal does not work - Car Audio & Video
Anonymous
Level 2:
Scholar:
  • Expert 80 Answers
  • Posted on Jun 12, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
39404
Points
167
Swap your RCA's input to the amp. Does the channel that works switch to the other side? If so, then the problem is either your rca wire, or in your source unit. (try the wire first). If the same channel still is out, then problem in the amplifier or speakers. Move to swaping the speaker wires, right to left, and left to right... If problem same, then trouble is AMP, if problem moved, then trouble is speaker. If amp, remove amp, troubleshoot amp... (there are 3 basic parts to any amp... Power supply, input section, and amplifier section...) You know it's not the power supply because the sound is good on at least one channel, and most alll amps use one power supply for all channels, so if one channel sounds good, then you can rule out the power supply. Second, when an amplifier fails (usually, 90% of the time or more) it will result in a shorted output transistor or some other nasty condition that will blow a fuse, or toast a supply almost instantly, and again, your amp powers up, so odds are that the amplifier section of the amp might be ok. (no guarantee here, it's just the odds...I'd say it's like a 40/60 thing.... This leaves you to focus on the input section. First rule out the simple things... bad wiring, (rca, or speaker), bad speaker, bad source. Then rule out the simple things at the amp... broken rca input connectors (inside the amp at the PCB where the solder is) or outside the amp, where the jacks may have been crushed. Then rule out broken speaker terminals, where they can be cracked inside at the board where the solder is in the same way. After all this, you need your amp serviced by a qualified tech.
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
I m connected all the connection neatly,all the channals are appears well, but speakers are not working on tv tuner i.e i m unable to listen audio of all respective channals, so please give me solution...
yes you are right i aslo got problam in that..........join speaker lead in audio out.......and join green connector at the back of comuter <in which you insert the lead of speakers> to audio inakashbnsl31_6.jpg
I cant get the sirius to go past channal 39 it is telling me that the channales are preset. i dont have the manual for the stero so i dont know how to get all the channals to work.
  • [P/A] button Performs category scan while in the SIRIUS mode.When the button is pressed and held, preset scan is performed.
  • [DIRECT] buttons Stores a station into memory or recall it directly while in the SIRIUS mode.
  • [ > '' ] (play/pause) button Select a category [<<] rewind, [>>] fast forward button Press the button to select a station.
  • [FNC] button Press the button to switch the operation mode among the SIRIUS mode, etc.
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Hi i have a tv from a hotel and it will only turn to some channals not all how can i reset the channals
i believe youre gonna need the remote control , what brand and model ?? AJ
2helpful
No sound from MSI K8MM3-V.. Can't get my Logitech z-5500 working with my MSI K8MM3-V.. There arent comming any sound out of the ports in the back.. :( I can get the stereo working in the front...
Try reinstall drivers (if dont have download here) then find VIA AUDIO DECK in the system tray and check under the "phone jack" and under the "speaker" parameters and correct if anything wrong. Choose 6 channal and if your motherboard has self detection function of sound devices when plug it pops up and choose correct channal per jack. your logitech connectens here see how to install.
Info service
Go to the Messages and then tap on info service and add the new channel with value 50. it will work now.
Thanks,
Rajendra
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
2answers
HELP!!!
Go back in the menu, find (input source) or (tuner) then click the cursor right side of the menu button or the left to move the (TV) to (CATV), after you bring it up then move cursor arrow up or down to page (AUTOPROGRAM) then tap the cursor arrow right of the menu button to start the CATV channels to be found , be sure you have the cable connected to the TV. Once the channels have been found, tap (EXIT) or (STATUS) button on remote to get out of the menu and close the page, or just turn set off and back on again.
Channal Search
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
