Electric Razor Pocket Rocket Ride-on Motorcycle Logo
A
Anonymous Posted on Feb 12, 2014
Electric razor pocket rocket ride on motorcycle
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Razor pr200 pocket rocket. the tire is moving when i lift it up but when i sit on it it wont move
#1 check your power voltage on your batteries #2 you need to check the power to the electric motor - #3 possibly replace the control module - #4 possibly replace the throttle
Switch is on and red lite is on but will not run.
Use an allen wrench and remove the seat. check to see all the wiring connectors are joined to each other properly.
1helpful
No power on back wheel just a red light on the off and on switch
try unplugging the brake wires. if this does not work, it is prob. your throttle.
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
