IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
A
Anonymous Posted on Feb 12, 2014
The power adapter is dead. how do i order a new power supply?
What can cause the printer to not power up?
Check the outlet, it could be that the outlet that supplies electricity to your printer is itself dead. try plugging something else into it.
2answers
Will not turn on
power issue on board or bad memory check to see if you have any lights when plugged in and does the laptop make any sounds like it booting up when turned on or is it totally dead if dead check power supply if that's good you have a bad power linked to board if that's the case go to best buy.com in clearance theres great laptops there for 319.99
Computer will start to power up and then shut down.
Could be burn out power supply or dead battery before buy a new one borrow from a friend similar adapter with similar ratings
Adaptor not working
if you are positive that the power adapter is dead you will have to get a new one either from a local PC store or order it online. The best way is to just browse ebay for a new adapter. Don't opt out for an old/used adapter unless the seller guarantees it's perfectly functional and offers at least a week of full money back guarantee. Power supplies can cause a whole lot of trouble such as random freezeups, shutdowns and slowdown of the computer, so although it's a more expensive option, it is best to get a new original laptop power supply. It shouldn't cost more than $50.
Laptop will not power up, ac adapter issue, battery, or someting else?
You can try taking your battery off the laptop and just have the power supply hooked up. If it will start up like that, your battery or the charging portion of your motherboard is probably bad and you should have a technician look at it. If it doesn't start, your power supply is more than likely bad and you can order a new one from eBay. Also check to see if there are any lights on the computer or power supply. If the laptop has lights on it is almost definitely a laptop issue, if nothing is on (including the light, if there is one, on the adapter) then it's probably a adapter problem and your battery is dead. You could try getting a new one on eBay or a universal adapter in a store. That way if the adapter turns out to be ok you can return the universal adapter.
1helpful
I have an old SPX90 Digial Reverb with a dead powersupply. The part number on the board is VA81400. Is this part number correct? Is the part still available? We tried ordering it from the Yahama dealer,...
Any power supply will do as long as it has the same specs as the dead one, which will be:
Input : x Volts AC
Output: x Volts AC or DC
Watts: x
Amps: in millamps
Polarity: (for power supply with DC output only) Center pin = plus or Center pin = minus
You should be able to find the matching transformer/adapter/power supply at Radio Shack.
More info, let me know.
Charlie
P.S. The power supply you received may be the correct one -- check to see if the specs match the old one.
2answers
My power supply is dead how do I order a new one.
You can get one from lexmark, or off of ebay. Your power supply will say how many volts it outputs.
Match this up with new one
You also get one from
www.newegg.com
www.argecy.com
or others. Just type in your model #
2answers
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
3helpful
2answers
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me [email protected]
Battery does not charge
you may need to get a new one try that ok
Top IO Magic Corporation Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
