Question about Motorola Mobility RAZR V3x Cellular Phone
My razor is instantly turning off and sayin insert sim card but the sim card is correctly in
    Scholar:
  • 75 Answers
Check whether there is any fluff, dust or grease on the SIM card contacts or on the contacts in the phone body. Also check that the SIM card is properly aligned and a reasonably tight fit in its housing
Posted on Jun 08, 2009
6ya staff
SOURCE:
Phone keeps sayin insert sim
Hi,is your mobile saying to insert sim card even after inserting a valid card into your mobile? it means that your mobile is locked..to unlock it you can contact your current provider to get unlock codes to unlock your mobile or can get it from online providers..once i got unlock code for my mobile from classicunlocking and unlocked my mobile..you can too try getting codes for your mobile and get it unlocked..but before that check whether unlock codes for you country and provider..
Aug 02, 2011 | Motorola Mobility FOR MOTOROLA RAZR RAZOR...
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Motorola displays insert sim and sim is inserted
alot of razors have this problem....fold a peice if paper and put it over the sim card under the battery..this should put more pressure on the card to help it connect... this helped my phone,,i hope it helps you...thanks and have a great day
Nov 08, 2009 | Televison & Video
Msg on 4 year old Razor says "Insert SIM", but the SIM Card is in the phone. What do I do?
Hi friend,
I think you may check if the problem is from the card slots,may be the sim card doesn't insert deeply or the card slot is loosening,you can try to insert it deeper and tighten the slot.
Or you can try to...you can get more information on the website: www.1010store.com.
Aug 31, 2009 | Motorola Mobility RAZR V3
My signal keeps sayin SOS and it tells me to insert sim card when
1.check the sim card if it is properly inserted.or try other sim card.
2.did you turn on your wifi?turn it on to have a signal from your network.
3.Is it unlock/openline already?
4.if the above mention is still not working its already a hardware problem.
Jul 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My phone keep sayin i shud insert sim
Kindly remove the sim card on the phone, there is a gold plated part on it right? kindly wipe it with a dry clean cloth then place it back in, let see if it will work.
Jul 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Can accsess my phone but sayin sim inactive
hi hitesh her from tirupati ceelluler good morning i have problem of ringer of 580
Jan 22, 2009 | Sony Ericsson w580i Cellular Phone
Insert SIM message
try your sim card in someone else phone it might be the sim card not the razor
Mar 31, 2008 | Motorola Mobility RAZR V3
Water in phone
Alright so if you got a new sim it's more than probable that the connection is the problem. Remove your sim and take an eraser and clean it gently. Make sure you have the sim connector properly connected to the sim card, so leave the back off and turn it on I had to slide my sim card around a few times for it to work so try that till the message disapears. hope that helps.
Dec 13, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3x Cellular Phone Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
