Try switch off and on see if it persist then then try hard reset U tried hard reset it by holding the power button and volume when tablet off then going down to factory reset by using down button and press power button ok go down to yes and that will hard reset but make sure u back Ur tablet up before u perform an hard reset
Good Morning, Sorry to hear of the trouble you are having. Here is how to bypass rhat pattern. Hope it helps...
OW TO RESET THE STAR and NOVA TABLET
regarding an issue recovering the pattern lock on your Nova. Unfortunately, the only way to remove this password is to reset the device completely to factory settings. Please follow the steps below to correct this matter:
1. Power off the Nova by holding the power button for two seconds until you see "Power Off" on the screen. Choose the "power off" option and then press the "Ok" button. Let the device completely power down before you continue with the next steps. At this time also remove any SD card you might have inserted into the device.
2. Press and hold both the volume + and - buttons. While still holding these buttons, press down on the power button. You will then see a white screen that says Pandigital. This is the boot screen.
3. After the device boots up you will go to a black screen with yellow text, this is the system recovery screen. While on the system recovery screen, press the volume + button until "wipe data/factory reset" is highlighted. Press the volume - button to select this option
4. Press the volume + button until "Yes -- delete all user data" is highlighted. Press the volume - button to select this option.
5. The device will reformat and return to the system recovery screen.
6. "Reboot system now" should be highlighted by default. Press the volume - button to select this option.
The device will reboot and take you through the initial device setup
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. Reset iPadsettings.16 Apr 2013
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
for soing a hard reset you need to do te following things:-
1. go to settings
2. open backup and reset
3. click on "restore to factory settings" option.
