Make sure you have a dial tone.
Plug a phone in the wall to check( using the same cord. Then plug cord going from wall into "tel line" and check fax mode if you have a dial tone.
I don't think the 2, or 4conducter cord matters since the split out the same way
resolved my issue for my - web
Sir/Madam
Solution one: Check the fax connections
Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Figure 3: Fax only
Figure 4: Fax and telephon
Figure 4: Fax and telephone
1 - Telephone jack
2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephi cant send a fax or reseave one - a97fe5c2-e32c-4ca0-aabd-68855faaf816.gif="/uploads/images/a97fe5c2-e32c-4ca0-aabd-68855faaf816.gif" alt="a97fe5c2-e32c-4ca0-aabd-68855faaf816.gif" class="h_mi" />
Or
3 - Optional telephone cord to telephone
4 - Optional telephone
5 - Answering machine
6 - Two-wire telephone cord to 1-Line
If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
