I'm connected to the same wifi network, but can't connect to the hp 1220c?
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections
Symptoms
This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution
Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior:
Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved
Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information
Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
is your printer airprint enabled? its need this to print. official list is here:http://support.apple.com/kb/ht4356
if its not, try an app like printcentral
SOURCE: Need connect HP Officejet 7210 printer into wifi domestic network
Check your drivers at Driver Detective
If your computer does not recognize the printer, try going into your printers in the control panel and go to add printer and see if it finds it.
