Sony ICDP620  Digital Voice Recorder Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rewinding to listen to recording
When I push the rewind button the recording goes back to beginning. I am transcribing the recording and would like to rewind small increments at a time.
A Soveral
Level 3:
President:
  • Master 566 Answers
  • Posted on Jul 28, 2009
A Soveral
Master
Level 3:
President:
Answers
566
Questions
Helped
275927
Points
1995
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
How do you rewind while dictating with the Olympus DM 620?
To rewind, you simply push the rewind button. However, this does not rewind from the point you are at like a tape does, it goes to the beginning of the recording. Once you are in the play mode, pushing rewind will rewind from that point.
2helpful
Instructions mdlp minidisc player
you need to push the button longer so it will wind. remember short push is next or back track and long push is winding
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
1helpful
How do i erase a tape on the Dictaphone 2740 transcriber?
Hello Just Press and Hold the erase button located on the bottom rigth then press rewind. All the rewind part will be erase.
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
How do I rewind
by just pressing the rewind button, it goes to beginning. by press and holding down the rewind button, it will start rewinding slowly and get faster the longer it is being held down.
Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
12helpful
3answers
My T1000 will not erase tapes.
Press the erase and rewind button at the same time.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
