SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
SOURCE: My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
SOURCE: When I press the start button, Bosch dishwasher
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
SOURCE: We have a 8 y.o
Hello, welcome to FixYa.
Based on your post and my experience with Bosch, If it does fill with water as you said I have a question to it's behaviour once filling stops. Do you hear a humming begin after it has filled, and if so has the unit recently been idle for a period of time...say a couple of weeks or so ?
If yes, the wash impeller has possibly become stuck and if so there is a simple resolution for Bosch dishwashers, it's a common occurrence.
These are relevant questions and can point directly to the problem if you want to reply I can help you move forward.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
