Oven knob rotares and unable to turn gas only from yhe gas line in rear of stove
SOURCE: recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
SOURCE: Safely remove knobs from 50's Kenmore gas stove
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
SOURCE: Gas Range Oven Knob Area Gas Leak
The only two things you can do are pull the core of the oven thermostat and re-grease it, but that could throw your temperature calibration way off. The other is to replace the thermostat. Either way, a calibration is probably a good idea.
