Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does code 2454 mean on the konica minolta
What oes code 2454 mean on the konica minolta bizhub pro c6500?
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jul 31, 2009
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910516
Points
11959
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3684
Points
I'm having an error code c2454 on my Konica Minolta 6500. Would an inadequate amount of developer give me this service code? I haven't had developer added in months.
nsikak emmanuel
Level 1:
New Friend:
  • Posted on Apr 22, 2015
nsikak emmanuel
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3684
Points
Write your answer...
IF. the problems still keep doing wat will I do to stop it. Frm d erorr. PlZ help me I hv wrk do deliver
Joy rb
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 23, 2013
Joy rb
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4014
Points
Konica Minolta bizhub PRO C6500. Hello, can anyone help me? Do I have a problem with code C2221?
Question edited for a lot more clarity.
Question translated to English, we only speak English here.
Question moved from Televisions category.
Konica Minolta Bizhub PRO C5500 Solution Manual (Page ...
ManualsLib https://www.manualslib.com > ... > Solution manual
Reconnect the terminal. 2.Failed ...
Accurio c2060 error c2221
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Jun 26, 2023 - C2221 can be caused by toner dusted sensors PS50 & PS51. I've seen C2221, when the drum bore fits too tightly onto the drum shaft. The imaging ...
Error Code C-2221 on C7000
Apr 3, 2019
C6500 Error codes C-2211 - C-2214
Aug 7, 2008
bizhub PRESS C1060 multiple codes/symptoms
Jun 21, 2022
C6500 C-2220 error
Jan 22, 2014
More results from www.copytechnet.com
Error code c0101 - Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Printer control board (PRCB) or Paper feed motor (M41) is bad hope its the motor board will be expensive!!!!!!! check behind the draws paper stuck!!!!! also pull out each draw find if thats the problem
C 2454 Code
Printer control board (PRCB) 4 choice $$$$$$$$$$$$$$$$$$$$$$$$
Developing motor/K (M23) 3 choice
TCR sensor/K (TCRS/K) 2 choice
1. Clear black developer counter, replace the black developer an run required procedures
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
2helpful
2answers
6helpful
2answers
Konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
