how to video
F paper jams inside the printer, the printer will stop. One of the following LCD messages will appear to tell
you where to find the jammed paper.
Check where the jam is and clear the jammed paper referring to appropriate FAQ below.
If the error message still appears on the LCD after you remove the jammed paper, there may be more paper jammed somewhere else. Check the printer thoroughly.
After you have removed all the jammed paper, open the front cover and then close it again to start printing.
Note
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
Related:
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
SOURCE: I believe there is a
I knew I had to take out the toner cartridge but I couldn't remember if it was one piece or two. I went to over a dozen websites before I found some details beyond "Take out the cartridge." However the image was not clear. I asked for help from my wife, who knows less aobut computers than I do. She said, "It's definitely two pieces," and took the toner cartridge out, whereupon I removed the paper stuck in there and put the toner cartridge back in. Moral of the story: When even the instructions fail, ask you wife. Thank you, dear!
SOURCE: Paper tray is broken on laser printer Brother HL-5140
I believe you have to call you manufacturer and ask if you can purchase the tray separately. They might also give you a company that manufacture's parts of their printer.
Unfortunately I don't have any number about brother but you can visit their website and you might find their number.Their website is www.brother.com
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
