Netflix will not connect on iPad 1 says needs different ios
How to Install netflix on iPad first gen.:
first make sure your iPad 1st. gen is on
iOS 5.1.1 ! (=newest iOS running on first gen. iPad)
- It is possible, a bit tricky, but possible.
First, you'll need to download the Netflix app through iTunes on your computer, this will make it show up as "purchased" in your library. After that, open up the App Store on your iPad 1 and go to the 'purchased' tab. When you try to install it this way it will tell you that you need iOS 6 or higher, but will also ask if you would like to download an older version of the app. then click on download.
- again step by step:
1) Open up iTunes on your computer
2) Go to Store (left hand column) ->iTunes Store
3) Search for Netflix; - download the app
4) then open App Store on your iPad
5) Click on 'Purchased'
- you will have to install NetFlix by clicking on it as usual.
App Store will ask you: "Download an older version of this app. The current version requires iOS 6.0 or later, but you can download the last compatible version.",
then click on Download and it should finally work.
SOURCE: "No signal" on hdtv while trying to watch netflix via xbox
First you need to eliminate the possibility that
the box is loosing video feed from the G.P.U.
hook the unit up in with normal yellow
white and red a/v connection for standard TV
out . if it happens shut the unit off and on again
and if you have sound and no video it's the G.P.U
becoming disconnect , the fix for this is to have
the chip re-flowed back to the P.C.board .the other
cause is a failing HDMI cable but im guessing you
already replaced that.
If you have any questions feel free to ask
Rob
Testimonial: "Very helpful"
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: Netflix on ps3 keeps saying
This sounds like a problem with your Internet connection/networking.
Run the PS3's network test to get more information as to what is being restricted.
http://manuals.playstation.net/document/en/ps3/current/settings/connecttest.html
SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
