Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red lamp light stays on,tv wont power up
Hitachi 50" rear projection tv. when turned on the blue and the two red lights flash. after a short time the red lamp light stays on and the tv stops trying to power up.I replaced the bulb because it was blown. help please
Anonymous
Level 2:
  • Expert 197 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
Answers
197
Questions
0
Helped
91241
Points
366
Lamp door has to be closed
Hitachi projection tv quit
Pls check that model number........the problem description does not match that of a 1999 crt proj tv.........I believe yours is a newer lcd projection around 4 or 5 yr old?? Lamp light flashing on any brand is indicative of the lamp not lighting . The lamp is the most likely cause,but the ballast board can cause this as well..................you should see an access door refer to owner book of the correct model and you can replace yourself...........it may cost around $200 and avaiolable at encompass parts .com Hitach distributor
5helpful
Tv not turning on
Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
1helpful
TV will not turn on. Lights Blink and hear noise
Have you replaced the lamp ? Make sure the door cover is closed good because there is a switch that is made when the door cover is put back on. Also you could have a bad ballast board or bad power unit board. Just a thought...... Hope this is helpful.
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Tv wont turn on
I have a 52" RCA projection tv that won't turn on.
No Picture on screen
THIS PROBLEM HAS HAPPEN TO ME WHEN MY LAMP WAS
ABOUT TO DIE. WHAT I DID WAS UNPLUG THE TV SET FOR
A SHORT WHILE, THEN WHEN PLUGGED AGAIN IT CAME ON BUT THE PICTURE WAS DIM AND THE LAMP ONLY
LAST FOR FEW DAYS AFTERWARDS.
W.J.M.
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Hitachi TV no picture no sound
Most common fix is shorted cap C702 ? near flyback transformer
and open E994 pico fuse in power supply. Capacitor is sometimes partially covered by glob of glue from factory....
Let me know right away,please......................T.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
