Sewing Machines Logo
A
Anonymous Posted on Feb 05, 2018
Service center new delhi
My brother sewing machine was given to a local fixer as the thread kept breaking. I was told that they would contact your service center and get it fixed. But nothing was done. I have now got it back and it is a mess. I live in defence colony New Delhi, where can I take it now to be repaired.
R.A. Ellis
Level 3:
  • Brother Master 12,731 Answers
  • Posted on Feb 07, 2018
R.A. Ellis
Brother Master
Level 3:
Answers
12731
Questions
Helped
2613675
Points
59176
You can probably search the internet for sewing repair service in your area. Other than that, you can try finding the issue yourself.
sewing machine breaking thread Google Search
.There are several things you can try: replace the needle, replace the thread with a different brand, is the thread too large for the needle, are the thread, needle & fabric compatible, verify it is threaded correctly, clean the bobbin and feed dog area, check for burrs or nicks along the thread path, loosen the top tension. NOTE: be sure to ALWAYS RAISE the presser foot when threading the top thread!
All About Needles SCHMETZ Needles
Jody Jernigan
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
Jody Jernigan
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
Helped
3267
Points
41
Not sure where you can take it. Check your thread tension and bobbin tension. Make sure they are not too tight. Also, how old is your thread? Many times, old thread will break easily. Check your needles for burrs. If there is a burr, the thread will break constantly when the needle moves up and down as it catches on the plate.
5 Related Answers
Anonymous
  • Posted on Nov 16, 2008
SOURCE: Brother XL-5340 sewing machine
I have the same problem! except mine doesn't break thread, it just comes out. Oh, mine's a ELNA Transforma
Anonymous
  • 55 Answers
  • Posted on Jul 27, 2009
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Anonymous
  • 1126 Answers
  • Posted on Sep 17, 2009
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Anonymous
  • 96 Answers
  • Posted on Dec 13, 2009
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Anonymous
  • 53 Answers
  • Posted on Jun 07, 2010
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
My Brothers 2003 ult D continues to embroider after the upper thread breaks. No notice of thread break and it continues to run. What can I do. I do not have a service center near me.
Change thread for a new spool and thread can deteriorate and go rotten. Make sure threading is correct and especially between the discs in the tensioner.
1helpful
What size needle do I need for a brother db2 755 mk3?
Contact your local Brother dealer. They carry the needles you need for your machine. The needles should all be the same length for your machine. If you continue to have issues with your machine, be sure that you ALWAYS RAISE the presser foot when threading the top thread. If there are still more problems, you may have knocked the machine out of time when it broke the needle.
Have a Brothers pe770. Having trouble with thread contently breaking but just kept rethreading. Tonight the little long brush on take-up lever feel off. Can I still use machine? How do I fix this?
If the tread keeps breaking could be it's old thread, need new needle or needle and thread not the right combo for material. Or yiur tension is too tight.
not sure about the brush falling off. Up to you to try sewing.
2answers
I need to talk to someone
go to a sewing machine repair shop ( preferably one that services your make of machine ) and talk with them as to what is happening and what you are doing
Brotherps31 instruction manual
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
to find a manual, we have to know the model number of the machine
to to
2answers
Thread Breaks
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
1helpful
My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
