I'm having problems IMPORTING FILES INTO THE KORG D3200 I've tried every kind of audio file with the spec's in the manual on page 86. sampling freq. 44.1 kHz,48kHz,*96kHz - bit depth:16-bit,24-bit.I burn the CD & every time I load it into the korg it says "this format is not supported" & so far everything that I have read on the internet does not work?
SOURCE: Hallo, I have a Korg pa800 and whenevery I want to
you may have to dump somethings from the memory, the memory is finite and if there is no more room there is no more room. as far as I know there is no expansion memory for this keyboard
Testimonial: "Thanks, That is what I thought to be the problem, but I don't knnow whichthings to dump/delete from the memory. I don't want to destroy other things."
SOURCE: Hello, I have a big
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
After updating the firmware, you likely must do a factory reset. This is probably required so the keyboard will read and decide how much ram actually exists. At this site do the "factory reset" version:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
SOURCE: hi i got the korg
Hi
I have the same problem here, just happened today. Can you update me on the status of your device and how you fixed it?
Thanks
SOURCE: have korg d3200. gray
i'm stuck on the start from cd screen and have the cd but it doesn't do anything can anyone help me?
I'm surprised that no fixya experts can answer this question.
i'm assuming your importing these files from a computer-at this point what os are you using & make sure the drivers aren't corrupted-if i'm missing the point please let me know
